I have a workspace that I am running locally on my computer. This workspace is connected to an sde database on Amazon EC2 instance. This workpace is very simple translation just a reader and a writer, the purpose of the workspace is to completely delete all features from the sde database. However when I publish this workspace to FME Server the translations fail due to this error.
2020-10-18 05:39:39 | An error occurred while attempting to open the table,[...]. The error number from ArcObjects is: '-2147216057'. The error message from ArcObjects is: {Invalid parameter value passed to function}
2020-10-18 05:39:39 | It could have failed to open because it contains ArcGIS Pro-only features, for example Arcade expressions. If this is the case, please install ArcGIS Pro or Pro-compatible ArcGIS Server and 64-bit FME
Has anyone had an error like this before? I just don't know why desktop workspace works fine but once it is published to FME Server the workspace no longer functions, is weird.
