Best EC2 instance type for FME
9val
Hi all,
Could you please share your experience on what types of AWS EC2 instances you use for FME Flow and FME Form. I wonder if the M5 instance type is recommended since it is used for FME Flow Hosted. We mostly use “t3.large”.
I understand that the choice depends on server load etc., but I would like to know the best practices.
Thanks!
Forum|alt.badge.img+53
  • March 9, 2025
For training we use t3(a).xlarge. Its sufficient for that purpose, but I would want a more powerful instance for large data processing.
One thing to also consider is the iops of your storage, the higher the better (faster)
redgeographics
Forum|alt.badge.img+49
It really depends on what you want to do with it. Higher specs means shorter processing times (more or less, there’s a lot of factors involved of course) but it’s up to you to decide whether the extra cost is worth it.
