I have a first shapefile with points indicating the number of inhabitants. I have a second shapefile with surfaces. I would like to know the number of inhabitants for each surface in FME. What is the process?
Calculating population from point located in a buffer/surface
Best answer by nielsgerrits
You are probably looking for the SpatialRelator. As an alternative the PointOnAreaOverlayer can be used.
