Mulitple triggers in an automation?
  • February 6, 2025
  • 0 replies
  • 39 views
dms2
Forum|alt.badge.img+11
I’m sure I read somewhere you cannot have multiple triggers (of a certain type) in an automation, but I don’t know if this was only valid for some old versions of FME Server.
The thing is that a customer has FME 2022.2.2 and asks us to give them indications to build an automation (they’re not giving us access to their FME Server, which makes everything a bit tedious). I planned to have 2 webhook triggers, each of them would execute a workspace and both workpaces would be connected to the same ‘Send email’ external action. Each workspace would have 2 additional ports with the ‘email to’ and a pdf to attach to the mail to send.
Now, is this possible in a 2022.2.2 automation or should I build 2 separate automations?
Thanks!
Be the first to reply!
