Hi all,
I am working on a translation in FME, and I’m encountering an issue where my data is being fanned out to multiple locations. However, when FME tries to write the shapefiles to the first file location, the translation stops without any specific warnings or error messages, other than the general "Error running translation."
Interestingly, on FME Flow, the process behaves similarly. It doesn't throw any errors, but the translation simply stops after attempting to write to the first location, as if it's hanging or failing silently.
I’ve tried to troubleshoot by checking the file locations and permissions, but the issue persists. I would appreciate any guidance or suggestions on what might be causing this or steps I can take to diagnose it further.
Thanks in advance for any help :)
