How to convert cog tiff to citygml TIN relief?
  • January 28, 2025
  • 59 views
model_art
I want to convert a tiff to TINrelief in citygml. Is there a fmw workbench file or step by step guide for this? I’M a complete begineer to fme and citygml format.
virtualcitymatt
Forum|alt.badge.img+35
Reader > TINGenerator (you can experiment with the tolerance to get a balance between detail and performance). You can take a look at the transformer help to get a good explanation of how the tolerance works. > CityGMLGeometrySetter > CityGML Writer.
Something like the below.
model_art
  • January 29, 2025
Thanks ​@virtualcitymatt . I tried this but upon validating the output using 3dcitydb imported, it throws this error:
“[18:07:46 ERROR] Invalid content at [11, 10]: cvc-complex-type.2.4.a: Invalid content was found starting with element '{"http://www.opengis.net/citygml/relief/2.0":tin}'. One of '{"http://www.opengis.net/gml":metaDataProperty, "http://www.opengis.net/gml":description, "http://www.opengis.net/gml":name, "http://www.opengis.net/gml":boundedBy, "http://www.opengis.net/gml":location, "http://www.opengis.net/citygml/2.0":creationDate, "http://www.opengis.net/citygml/2.0":terminationDate, "http://www.opengis.net/citygml/2.0":externalReference, "http://www.opengis.net/citygml/2.0":generalizesTo, "http://www.opengis.net/citygml/2.0":relativeToTerrain, "http://www.opengis.net/citygml/2.0":relativeToWater, "http://www.opengis.net/citygml/2.0":_GenericApplicationPropertyOfCityObject, "http://www.opengis.net/citygml/relief/2.0":lod}' is expected.”
Does this mean I need to add more citygml related data to this? Could you please guide here?
kailinatsafe
Forum|alt.badge.img+21
Hello ​@model_art, how did you create the writer feature type? Seems like there may be content missing from your output.
Did you import the schema from dataset, as seen below?
When the import wizard pops up after clicking OK, leave the dataset blank and hit OK again. You will want to write to the ‘TINRelief’ feature type.
Now, if I went to write at this point, I would see a validation error that some elements were missing, sort of similar to what you were seeing from 3dcitydb.
To resolve this, add an AttributeCreator and set citygml_level_of_detail as ‘0’, ‘1’ or ‘2’ (for example).
These steps allowed me to produce a successful CityGML 2.0 dataset I can open in third party viewers. I’ve attached a workspace as an example. Let me know if you are still having issues! Happy to help, Kailin.
