Version Control issue: Push to Remote not working
  • January 23, 2025
  • 63 views
laurensdelfland
I updated FME Flow from 2024.1.1.1 to 2024.2.1. After the update Version Control isn't working anymore.
The Fetch From Remote-button works fine, but when I click the Push to Remote-button I get this error:
Could not push to remote repository. Cannot invoke "org.eclipse.jgit.transport.RemoteRefUpdate.getStatus()" because "refUpdate" is null
Does anyone have an idea what the problem could be?
(I already created a support ticket with my local reseller, but they haven't seen this issue before)
virtualcitymatt
Forum|alt.badge.img+35
Certainly not a helpful error. It could be a bug if you said that is worked fine in an older version. Did your reseller forward your request to Safe Software?
laurensdelfland
No, not yet. They asked if I checked this page: https://support.safe.com/hc/en-us/articles/25407577604365-FME-Flow-Troubleshooting-Version-Control
But that was not helpful.
I can commit, just not push. The SSL error doesn't seem to be the problem, but to be sure I added the certificate of https://dev.azure.com/ to the store. That didn't help.
Now I'm waiting for their reply.
laurensdelfland
tl;dr: Before the update FME Flow created the "master" branch and did everything in that branch.
After the update it seems that FME Flow has checked out a branch called "main" and created it in the remote repository. But somehow FME Flow is expecting the "master" branch.
I don't know exactly what I did, because my git-skills are quite limited, but I checked out the master branch on the FME Flow-server and now it works fine.
I do think it is some kind of bug in FME Flow.
1. Opened a command prompt and went to: D:\ProgramData\Safe Software\FMEFlow\repositories
2. entered: git checkout master
got this message:
error: Your local changes to the following files would be overwritten by checkout:
        Scheduled Workspaces/DubbeleCodeMailer/DubbeleCodeMailer.fmw
Please commit your changes or stash them before you switch branches.
Aborting
3. entered: git commit
got this message:
On branch main
Changes not staged for commit:
  (use "git add <file>..." to update what will be committed)
  (use "git restore <file>..." to discard changes in working directory)
        modified:   Scheduled Workspaces/DubbeleCodeMailer/DubbeleCodeMailer.fmw
Untracked files:
  (use "git add <file>..." to include in what will be committed)
        Dashboards/
        Internal-4f281d882ec3/
        Samples/
        Scheduled Workspaces/TerugmeldingenEmailer/
        Utilities/
no changes added to commit (use "git add" and/or "git commit -a")
4. entered: git stash
got this message:
warning: in the working copy of 'Scheduled Workspaces/DubbeleCodeMailer/DubbeleCodeMailer.fmw', LF will be replaced by CRLF the next time Git touches it
Saved working directory and index state WIP on main: 234a57f Nieuwe versie met Sharepoint transformer
5. entered: git checkout master
got this message:
Switched to branch 'master'
Now it all works fine.
I probably lost some commits, but I'm happy it works again.
