I have never used this functionality but I can reproduce this in 2021. If you really want to you probably can create a ticket at Safe, but I doubt they will fix it as 2021 is nearing end of support? There are alternatives:
Click in the canvas and enter a term you are looking for. Like “tableau”. Click on the hub transformer to download and install.
Go to https://hub.safe.com/browse and find the transformer you need, click on download and install manually by opening the .fmx
Thank you so much for your reply @nielsgerrits, and for checking this out for me to demonstrate its not just a isolated issue. I have been using workarounds like you suggested but thought maybe there might have been a easy fix and as you suggest I would imagine logging the issue might not be worth it when this version is nearing end of support.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
