Excel Writer: Output Field Names in Columns instead of Rows
  • December 11, 2024
  • 50 views
boxcase01
Participant
I’m using FME 2024.1.
I want to write xls files out where my field names appear in Column A (with their corresponding value pair in Column B) instead of in rows. Sounds simple, right?!
Writing the data out with an Excel Writer produces a default output like this:
Field Names in Row 1, values in the corresponding column.
...this doesn’t make for a particularly human-readable output when you have 250+ fields in the output dataset.
This is the style I would like the output to be in:
Field Names in Column A with matching values in Column B.
I have tried using an AttributeExploder to create name:value pairs but am having trouble getting from there to anything particularly useable (I still have a lot to learn about working with lists).
Oh, great hive mind, please help me out!
Casey
j.botterill
Forum|alt.badge.img+37
  • December 11, 2024
Hi there, you have a few options.
Start out reading over this article https://support.safe.com/hc/en-us/articles/25407761369741-Transpose-a-Table-Using-FME\
Custom transformer AttributeTranposer transposes attributes so that the value of a selected Column Attribute is turned into a new attribute. In other words, it's a simple version of the AttributePivoter that flips the "rows" and "columns" of a feature attribute table
