UserParameter values as attribute name
  • November 28, 2024
  • 48 views
lambertus
Forum|alt.badge.img+15
I would like to use 2 UserParameter values as attribute names in my workbench. Is this possibe?
Current situation:
What I would like to have:
veschwab
Forum|alt.badge.img+13
  • November 28, 2024
This is surely not an elegant solution but it seems to do the job:
You can try an BulkAttributeRenamer since I found you can use User Parameters when choosing what suffix/prefix you want to add to the AttributeRename. You can just choose to Rename Selected Attributes and select the attribute for FirstMoment/SecondMoment and then choose the corresponding user parameter in the “string” parameter. Maybe these screenshots help:
