I’m actually running an instance of FME Server deployed using Safe Software’s Helm chart.
The core component image version is 2024.1, and the HTTP readiness probe path is the following:
"status": "notReady",
"message": "One or more essential processes are unavailable.",
"components": [
"component": "notifier",
"status": "up"
"component": "connections",
"status": "up"
"component": "queue",
"status": "up"
"component": "resources",
"status": "up"
"component": "core",
"status": "up"
"component": "cleanup",
"status": "up"
"component": "configuration",
"status": "up"
"component": "relayer",
"status": "up"
"component": "scheduler",
"status": "up"
"initializationTasks": [
"task": "installDefaultContent",
"status": "failure"
The problem seems to be with initialization tasks.
Do you have a pointer to where to look in order to fix this ?
