Extracting tables contents from webpage
  • October 1, 2024
  • 22 views
gisgeek
Forum|alt.badge.img+9
Hi there I have been trying to extract the contents of a webpage the Facilities Masterlist which is on our internal sharepoint. I have downloaded a local copy of the page I am trying to extract contents from and attached it. I haven’t had much luck extracting the contents to replicate the table on the page. This is what I have so far.
todd_davis
Forum|alt.badge.img+22
  • October 1, 2024
You can always try to read the table with the “HTML Table” Reader, if going via an html approach. Little bit of extra work to do, but it will give you a good start.
If you want the links, rather than just the text above, you can just change the reader parameters to not remove html formatting. e.g.
