I have created a workbench to detect schema different.
I am using two ChangeDector Transformer in this workbench which is producing output as I intend. Figure below shows that part.
This is output data (in csv file) based on that workbench.
However, when I used the same workbench with the same data, the following output were produced. It got extra error. For error code E302, those not bold should not be there.
The workbench used is the same.
The data is the same.
Only output 1 run in FME Workbench 2023.1 (FME Form 2023.1) and output 2 Run on FME Flow 2023.1.1.1 and FME Flow 2023.2.
Note: The additional error contain field that is unchanged in first ChangeDetector and does not included in the second ChangeDetector (ChangeDetector3)
