Issues with UTF-8 after upgrading to FME Form 2024.1
  • September 4, 2024
  • 100 views
rmpayaby
I have recently upgraded FME Form 2024.1. I tried to run a project, but I immediately got the following error message: “FME failed to restore the process locale to UTF-8. A non-UTF-8 process locale may cause undefined behavior.”
Is there any quic fix for this issue?
saraatsafe
Forum|alt.badge.img+9
  • September 9, 2024
Hi @rmpayaby, there isn’t a quick fix for this issue from what I can see, but I did find a couple of related bugs that are being addressed.
Would you be able to share your log file so that we can confirm if this is a related issue or a new one? Would you also be able to let me know what version of Windows Server you’re using?
