ProjReprojector fails to read the source coordnate system from features
  • August 26, 2024
  • 50 views
knutos
Hi there. I have encountered a problem with ProjReprojector and FME Form 2024.1.1. Source data is PostGIS and source coordinate system is EPSG:4258.
With the <Read from feature> option, only the first object that arrives the transformer is reprojected. Then it fails. I have carefully checked that all features that arrives the transformer is properly tagged with coordinate system EPSG:4258.
When I set the source coordinate system explicitely to EPSG:4258, everything works perfectly.
Any others that have seen this behaviour? With earlier versions og FME (FME 2020), everything works perfectly. Is this another issue with FME 2024?
j.botterill
Forum|alt.badge.img+37
  • August 27, 2024
Hi there, I’ve seen this in previous versions. It can be a frustration for sure. The workaround is as you found or to add a CoordinateSystemSetter.
I suggest lodging it to Safe support for a fix. https://support.safe.com/hc/en-us/articles/25407438078349-How-to-Create-a-Great-FME-Form-Support-Case
