Hi, I have a workspace that i want to compare timestamps between two rows in a database based on some matching information.
i’m using an sql extractor to pull the pertinent information, which spits out something like this:
IMAP TIME SUBJECT DATE
Tue Aug 20 02:42:25 EDT 2024 XXXXXXX_#6337.4 8/20/2024
Tue Aug 20 02:42:52 EDT 2024 XXXXXXX_#6337.4 8/20/2024
Tue Aug 20 04:06:13 EDT 2024 XXXXXXX_#704.0 8/20/2024
Tue Aug 20 04:06:41 EDT 2024 XXXXXXX_#704.0 8/20/2024
Tue Aug 20 05:33:15 EDT 2024 XXXXXXX_#7274.2 8/20/2024
Tue Aug 20 05:33:47 EDT 2024 XXXXXXX_#7274.2 8/20/2024
I’m then using a StringSearcher to extract the time with the regex \d+:\d+:\d+ and this gives me the time in essentially a %H:%M:%S format:
Extracted original IMAP (for comparison)
02:42:25 Tue Aug 20 02:42:25 EDT 2024
02:42:52 Tue Aug 20 02:42:52 EDT 2024
04:06:13 Tue Aug 20 04:06:13 EDT 2024
04:06:41 Tue Aug 20 04:06:41 EDT 2024
05:33:15 Tue Aug 20 05:33:15 EDT 2024
05:33:47 Tue Aug 20 05:33:47 EDT 2024
06:22:19 Tue Aug 20 06:22:19 EDT 2024
06:22:47 Tue Aug 20 06:22:47 EDT 2024
06:32:26 Tue Aug 20 06:32:26 EDT 2024
06:32:58 Tue Aug 20 06:32:58 EDT 2024
The extracted result isn’t recognized as time format, so, i’m trying to feed it into DateTimeConverter with the source format: %H:%M:%S (also tried without %S and as %S$) the transformer fails and i’m not sure why.
i get the following output in the translation log:
Restoring 10 feature(s) from FME feature store file `\AppData\Local\Temp\wb-cache-CIP_EMAIL_HEARTBEAT_8-20-24-KdQmlH\Main_StringSearcher_5 -1 61 fo 0 MATCHED 0 c6df3019477d52d3e74dc521846172057a12859f.ffs'
The below feature caused the translation to be terminated
Storing feature(s) to FME feature store file `\Documents\FME\Workspaces\CIP_EMAIL_HEARTBEAT_8-20-24_Edit_log.ffs'
Feature Type: `FEATURE_TYPE'
Attribute(string: UTF-8) : `02:42:25' is <null>
Attribute(string: UTF-8) : `BMS_Source' has value `Siemens'
Attribute(string: UTF-8) : `Date' has value `08-20-2024'
Attribute(string: UTF-8) : `Email_Source' has value `FME_Outbound'
Attribute(string: UTF-8) : `IMAP_Time' has value `Tue Aug 20 02:42:25 EDT 2024'
Attribute(string: UTF-8) : `PARAMETER_EMAIL_BODY' has value `
DateTimeConverter_2_<Rejected> (TeeFactory): DateTimeConverter_2_<Rejected>: Termination Message: 'DateTimeConverter_2 output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
An error has occurred. Check the logfile above for details
now, my assumption is that top attribute is the error Attribute(string: UTF-8) : `02:42:25' is <null>
but i don’t know why it is showing up as “is <null>”
i don’t see any extra characters or anything in it - the output from the previous step (i have formatting turned on)
the attribute says it is UTF-8 string:
I feel like i’m missing something obvious, but, i don’t know what - any advice would be appreciated
