I am getting the following error message when I try to run my workbench.
“FeatureWriter_UtilMaster (WriterFactory): MULTI_WRITER: No dataset was specified for MULTI_WRITER_DATASET or FeatureWriter_UtilMaster_13_DATASET or FILEGDB_DATASET”
I cannot for the life of my figure out what the issue is. My only theory is that because it is trying to write to a geodatabase, but the data I have been given to test with doesn’t actually have any geography. The writer is Featurewriter with output format Geodatabase (Esri Geodatabase (file gdb open api)) with the dataset as one of the attributes.
Does anyone have any ideas that might help, or think I might be on the money that the lack of geometry is causing a geodatabase writer to fail.
Feature writer no dataset specified
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
