Revit appearances?
jatoxa
Forum|alt.badge.img+12
What happened to Revit appearances in 24.1? Or did I miss some new setting?
2023.2
24.1
kailinatsafe
Forum|alt.badge.img+21
Hello @jatoxa, thanks for posting! Can you share a simple reproduction package please. This could include your source data, a revit template file, an fmw workspace, and potentially the version of FME being used? Happy to help, Kailin.
jatoxa
  • July 16, 2024
Hi @kailinatsafe,
Turns out I did miss a new setting as you have to select a view to get the proper appearances, so they’re still there. Not choosing a view will result in objects having a default appearance named “phase”-something, so I assume it's related to how Revit phases are read in FME.
One of the files I tested was this sample file https://revit.downloads.autodesk.com/download/2024RVT_RTM/Docs/InProd/racbasicsampleproject.rvt
Thank you!
