Managing raster files from API request
armando_amador
I have requested a raster file from an API (HERE Map Image API v3), and the response comes in the fashion of (I guess) base64 data.
I would like to have a way to transform such data and store it in proper folders.
Any idea?
Regards.
Forum|alt.badge.img+53
  • June 26, 2024
Two transformers to look at will be the TextDecoder (can decoded the base64) and the AttributeFileWriter which can write the contents of an attribute to a file
armando_amador
Hi @hkingsbury, thanks for your help, it helped to show the way to unlock AI capabilities in FME 2024, using PythonCaller I asked to the AI and it provided this code:
import fme
import fmeobjects
    def __init__(self):
        pass
        # Retrieve the _response_body attribute from the feature
        response_body = feature.getAttribute('_response_body')
        # Assuming response_body contains binary data for the raster
        # Convert the binary data to a raster file
        # This example saves the raster to a temporary file. Adjust the path as necessary.
        raster_file_path = r'YOURFILEPATH\raster.tif'
        with open(raster_file_path, 'wb') as file:
            file.write(response_body)
        # Optionally, set the path of the raster file as an attribute to the feature
        feature.setAttribute('rasterFilePath', raster_file_path)
        # Output the feature
        self.pyoutput(feature)
This helped to convert my api _responsebody input data and then stored it into the specific path.
Sharing it to newbies in the future to have a nice way to solve this issue.
Regards!
  • June 26, 2024
Nice job @armando_amador! Did you try the AttributeFileWriter? You’ll be able to achieve the same outcome without needing python
