Getting attribute information of multiple polygon intersected by line
hoa_le
Hi everybody,
I have a map with 'Layer A' (polygons district boundary) and 'Layer B' (lines roads).
I would like to add a field on my 'Layer B' table with the name of every district crossed by each road.
In this example, I would like my Road 1 attribute to tell me it crosses 'City A', 'City B', 'City C', and 'City D'. And my road 2 attribute to tell me it crosses ‘City A’.
Could you please show me how to make it? Thank you
Best answer by liamfez
I would suggest the SpatialRelator and Generate List of the cities. Then use the ListConcatenator to create the attribute that has all the city names for each road.
danilo_fme
Forum|alt.badge.img+44
  • June 17, 2024
Hello @hoa_le
I suggest you to use te transformer LineOnAreaOverlayer and enable the List Attributes.
hoa_le
  • June 17, 2024
danilo_fme wrote:
Hello @hoa_le
Hello @danilo_fme ,
If I use LineOnAreaOverlayer, it will split multiple road based on polygon? Actually, I want to keep number records in Road.
danilo_fme
  • June 17, 2024
Could you share your data?
liamfez
Forum|alt.badge.img+34
  • June 18, 2024
hoa_le
  • June 18, 2024
Thank you so much, I did it :)
hoa_le
  • June 19, 2024
Hi everyody,
If I want to calculate length intersect with each city or scale length of each road in the each city if the road cross. I dont’ want to use LineOnOverlayArea, because it seperate line.
How can I do? Thank you
lambertus
Forum|alt.badge.img+12
  • June 19, 2024
@hoa_le thats an interesting question. Although you dont want to use the LineOnArea Overlay tool, thats the tool you need in this case.
General Workflow
You need different transformers for this but the main steps are these ones:
  • Split the lines into sublines with LineonAreaOverlay
  • Compute the length of each subline
  • Join this information back to the original lines
You could include an attribute for example with the length distribution of the crossed cities in            your final dataset:
'Length per city':
1500 m - city A - 1000 m - city B - 2000 m - city C - 100m - city D
I can supply you with a workspace when needed :)
