Attache images to points data
  • May 15, 2024
  • 97 views
cosminciotina
I have a collection of photos and a point layer in SHP (Shapefile) format. I aim to replicate the functionality of 'Enable Attachments' from ArcGIS Pro. Specifically, I want to associate each photo with its corresponding point on the map based on matching the photo file names with a column in the point layer.
Is that possible? What transformers should I use?
donalmateer
Hey @cosminciotina!
Great question - this article may be able to help you in the right direction - https://support.safe.com/hc/en-us/articles/25407508005645-Writing-ArcGIS-Geodatabase-Attachments
Hopefully this helps and can guide you in the right direction!
