Iām trying to create a new value based on the first letter of each word in a string. I tested the regex ā\b(\w)ā and the returned value is correct, but when I used that regex in the @SubstringRegularExpression(), it only returned the first letter of the first word.
@SubstringRegularExpression(@Value(ID),\b(\w)) where ID is āMARKHAM RD/ORANGE BLVD, SANDFORDā. You can see in the regex editor, it is correct.
This is the result of the substring
