FME 2024.0 Prompt button
jeroenpeters
A small follow-up question, the prompt button on the toolbar has vanished for me since FME 2024.0. It also disappeared from the Toolbar options. Same goes for the Stop at breakpoint button.
Any ideas how to get it back?
Best answer by crystalatsafe
Hi @jeroenpeters and @jkr_wrk
We really appreciate your feedback on this.
We have restored the option to add the stop at breakpoints and prompt for parameters button to the toolbar in our latest release (2024.1) which can be found on our downloads page
crystalatsafe
Forum|alt.badge.img+18
Hi @jeroenpeters
I apologize for any inconvenience, but we have decided to remove the prompt button and the stop at breakpoint button from the main toolbar. After reviewing user feedback and analyzing the user experience, we did not find significant evidence to bring back these icons to the main toolbar. We wanted to preserve the main toolbar for actions that are more frequently used.
However, you can still access those actions through the run menu.
Crystal
jeroenpeters
  • May 1, 2024
crystalatsafe wrote:
Hi @jeroenpeters
Crystal
Hi @crystalatsafe,
thanks for the response, thou it’s sad to read these buttons are removed. Even the option to add them manually has been removed, I feel like that’s a bit of a design flaw 😊. No idea why you want to force users to go into the menu to check if these settings are on/off. It appears I could be the only one who uses it this way 😂
Have a great day!
jkr_wrk
Forum|alt.badge.img+29
  • May 1, 2024
To be honest I don't knew how to use the Stop at breakpoint function. Maybe I should use it more often. It could even function as a way to clear caching data. I should add a breakpoint after my Creator to force a refresh. My current method is changing the name of the _creation_instance parameter. My colleague presses the Rerun Entire Workspace and tries to Stop before the workbench comes to the critical part.
But removing the buttons from the Available Actions list is not “preserving” space in the Main Toolbar, it could only be “preserving” space in the Available Actions list. It’s more removing configuration options from the user. But maybe it was a hard time maintaining the button?
But if you really want to free space from the main menu:
Are there really people using the Cut, Copy, Paste, Undo and Redo buttons? And the zoom slider?
jkr_wrk
  • May 1, 2024
New toolbar:
Could be worse.
I think the FME Flow Connection takes up a lot of room on the bar. The new icon style is fashion i guess. I think less color is no progress, but that's taste.
jeroenpeters
  • May 1, 2024
jkr_wrk wrote:
New toolbar:
Could be worse.
But still, if it’s a user option you can move around icons and setup your own toolbar. Removing the option is really weird to me 😑
crystalatsafe
Thank you for sharing your feedback on this.
We have filed this internally for our development team to reconsider. (internal:FMEFORM-31102)
Crystal
crystalatsafe
  • July 11, 2024
jeroenpeters
  • July 12, 2024
Great news! Thanks Crystal 🙏
