AGOL Feature Service Reading Issue
  • April 10, 2024
  • 144 views
ileung_cnw
I've encountered a problem since upgrading to FME Workbench 2024.0. Previously, I could select Feature Services using Esri ArcGIS Online (AGOL) or FeatureReader without any issues. However, now I'm getting an error resembling the following:
"Could not find a Feature Service item matching the Feature Service directive 'Parks and Recreation - Tree Inventory/Tree Taxonomy List(<item ID>)'."
Interestingly, removing the quotations and <item ID> in the Constraints parameter allows successful reading. Is this the expected behavior? Do I now need to manually adjust parameters for reading every feature service?
Any feedback or advice would be greatly appreciated. Thank you in advance!
Best answer by j.botterill
I can’t see any fix coming in the change log of the next release 2024.1. You could try upgrading to 2024.0.1 (Build 24202 / April 3, 2024) however  change log suggests two fixes for AGOL feature service and these don’t appear to be related to selecting the Feature types.
Perhaps lodging a support case if you don’t hear from Safe Software here. Submit a Case | FME Support Center (safe.com)
j.botterill
Forum|alt.badge.img+37
  • April 11, 2024
