Extrusion with the normal instead of vertical
sami26beniaouf
Forum|alt.badge.img+7
Hello everyone,
Is it possible to extrude a surface through its normal instead of the vertical?
Thank you:)
Best answer by kailinatsafe
Hello @sami26beniaouf, thanks for posting! What version of FME Form are you using? (Help > About FME Workbench). Have you tried using the ‘Specified’ option for ‘Direction’ parameter? According to the documentation, the ‘Specified’ option should extrude along a vector, instead of vertically. Let me know if this works for you! Happy to help, Kailin.
kailinatsafe
Forum|alt.badge.img+21
  • March 25, 2024
danilo_fme
Forum|alt.badge.img+45
  • March 25, 2024
Awesome
