Sanpping Polygon to Polygon
mukhtarg
Hello Experts,
I have two Layers PD and AA. I want to align the PD layer to AA layer. Any help would be highly appreciated.
Thanks in advance
joepk
Forum|alt.badge.img+20
  • March 6, 2024
Hi, have you tried using the AnchoredSnapper? AA would be the Anchor and PD would be the candidate. I think Segment Snapping is the Snapping Type you want. You might have to play around with the Snapping Distance (maybe even increase snapping distance step by step) since it looks like there are some tricky geometries in there.
mukhtarg
  • March 8, 2024
Thank you very much ..willl try this
mukhtarg
  • March 25, 2024
I tried it but this is giving some false result. Shall i copy the shapefile to work here ?
