Write geometry to PostSQL Database
clowncutie
Forum|alt.badge.img+7
Hi, I have this workspace and databse connection, worked nicely to write to a table.
This is geometry column for another table in PGAdmin
My workspace using the PostGreSQL writer:
But for some reason, even if I add column geom manually in pg admin after, it refuses to write. What could I be doing wrong? The column jsut never appears, maybe it is a pgadmin question not FME question how I store the geodata, not as X,Y points but as readable geometry like this:
Best answer by nielsgerrits
What happens if you create the table using the PostGIS writer instead?
No expert but I think if you create the table using the PostgreSQL writer it is missing the spatial extension.
nielsgerrits
Forum|alt.badge.img+53
Are you using the postgres writer or the postgis writer?
clowncutie
  • March 7, 2025
PostGRESQL writer
nielsgerrits
  • March 7, 2025
clowncutie
  • March 31, 2025
I am stupid, I removed GEOM and used PostGIS writer instead to the database and that worked, usin geom as geometery column
nielsgerrits
Most of what I know is because I tried and failed :)
