Unable to read SHAPE file
fmeuser_gc
Forum|alt.badge.img+8
I experience this error while trying to load from shapefile reader to ArcGIS SDE on the FME server.
SHAPE Reader: Dataset `D:\\Apps\\FMEServer\\Data\\xxxxxxxxx.sde' lacks the required extension `shp'
Any ideas please? Thanks.
Best answer by stalknecht
A .SDE file is a connection file to a SDE database. It's not a shape file that's should have the .shp extension. Are you trying to read a geodatabase through SDE or do you want to read a shapefile?
Reading your question again I think you point to the wrong file for the shapefile reader.
Hi @fmeuser_gc,
Which reader are you using for reading shapefiles? There are several readers for ESRI formats so you might have to use another reader.
"Esri Geodatabase (File Geodb ArcObjects)" reader for featureclasses in file gdb's
"Esri Geodatabase (ArcSDE Geodb)" reader for SDE databases ("Esri ArcSDE" seems like an older version but maybe someone more knowledgeable than me can clarify this)
"Esri Shape" reader for shapefiles (featureclasses outside a database).
Hope this helps.
Marc
stalknecht
Forum|alt.badge.img+19
  • October 12, 2017
fmeuser_gc
  • October 12, 2017
Trying to read a SHP file reader and write to SDE.
fmeuser_gc
  • October 12, 2017
portofamsterdam wrote:
Hi @fmeuser_gc,
Hope this helps.
Marc
Trying to read SHP file reader and write to SDE writer. Point to be noted is it does run locally though, but not only in server.
fmeuser_gc
  • October 12, 2017
This is not the best answer yet. I still have an issue running it in server.
dustin
Forum|alt.badge.img+30
  • October 12, 2017
@fmeuser_gc Could you upload the workspace for us to see?
