Python Caller calculate field based on other attributes.
I am curious if it is possible to populate a field based on other feilds? Basically just how you would in arcmap via field calculator. Not sure how to make sense of the parameters in the PythonCaller transformer. And I'm not very experienced with python. Any help would be appreciated.
debbiatsafe
Forum|alt.badge.img+20
Hi @jlgvii
While it is definitely possible to set values based on conditions using a PythonCaller, a better method within FME would be to use conditional values within an AttributeManager or AttributeCreator. No Python required.
I would recommend taking a look at this article on conditional values if this is something you want to try:
https://knowledge.safe.com/articles/34109/determining-attribute-values-by-testing-with-condi.html
  • March 18, 2020
I entirely agree with @debbiatsafe, it's much easier doing this with regular transformers and a conditional value, especially if you have little or no prior experience with Python.
However, for reference, this is what the above might look like in Python:
import fme
def quadrant(feature):
    NorthAzimuth = int(feature.getAttribute('NorthAzimu'))
    if NorthAzimuth >= 0 and NorthAzimuth < 90:
        quad = 'N' + str(NorthAzimuth) + 'E'
    elif NorthAzimuth >= 90 and NorthAzimuth < 180:
        quad = 'N' + str(180 - NorthAzimuth) + 'E'
    elif ... # other criteria follows the same pattern
    feature.setAttribute('Quadrant', quad)
This will output the attribute 'Quadrant' with the result based on the input attribute 'NorthAzimu'.
  • March 18, 2020
debbiatsafe wrote:
Hi @jlgvii
Thanks this worked perfectly and will help greatly in other work as well. Thanks so much.
  • March 18, 2020
import fme
I appreciate the response. As I had tried to get this to work for a decent amount of time. But conditional values did get me the results I was looking for.
