FME Cloud post request
  • Jan 28, 2019 4:26 PM UTC
  • 10 replies
  • 121 views
oliver.morris
Forum|alt.badge.img+14
Hi I am trying to run this POST request but it doesn't pass the parameter correctly, can anyone kindly suggest what I am doing wrong? I am trying in Postman first and then will change it to work in SQL Server
Thank you
POST /fmerest/v3/transformations/transactdata/office_tasks/ROCK_PROPERTY_TO_TEAM.fmw?fmetoken=41544e72aac7b3da0b9095eac0cbdc23120b6d97 HTTP/1.1
Host: xxx.fmecloud.com
Content-Type: application/json
cache-control: no-cache
{ "publishedParameters": [
{"name": "file_path","value": "Rock_Properties_Upload_TEST1.xlsx"}
Best answer by gerhardatsafe
Hi @olivermorris The POST /fmerest/v3/transformations/transactdata endpoint is expecting a file as body and not a published parameters with the filename in it:
https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/transformations/post_post_24
If you want to submit a job with certain published parameters please have a look one these endpoints:
POST /transformations/transact/< repository >/< workspace >
POST /transformations/submit/< repository >/< workspace >
oliver.morris
  • Jan 28, 2019 4:35 PM UTC
it is something to do with the body, when i just use the default, without the body it works fine.
"timeRequested": "2019-01-28T16:33:33Z",
"requesterResultPort": 46477,
"numFeaturesOutput": 16510,
"requesterHost": "10.0.0.81",
"timeStarted": "2019-01-28T16:33:33Z",
"id": 325702,
"timeFinished": "2019-01-28T16:34:12Z",
"priority": -1,
"statusMessage": "Translation Successful",
"status": "SUCCESS"
oliver.morris
  • Jan 28, 2019 4:36 PM UTC
I took the published parameters straight from the FME server Rest API page which when run works fine:
{ "publishedParameters": [ { "name": "file_path", "value": "Rock_Properties_Upload_TEST.xlsx" } ] }
  • Jan 28, 2019 4:56 PM UTC
What exactly do you mean by "doesn't pass the parameter correctly "? What does the job log say about this parameter?
oliver.morris
  • Jan 28, 2019 5:05 PM UTC
thanks for the help David,
I just get:
"timeRequested": "2019-01-28T17:02:57Z",
"requesterResultPort": 45111,
"numFeaturesOutput": 0,
"timeStarted": "2019-01-28T17:02:57Z",
"id": 325729,
"timeFinished": "2019-01-28T17:02:58Z",
"priority": -1,
"statusMessage": "java.nio.file.DirectoryNotEmptyException: /data/fmeserver/resources/temp/geochem/office_loader",
"status": "FME_FAILURE"
Which basically is telling me it is trying to create a file where a folder currently is (from a previous run) the reason it is trying to create a file is that the parameter isnt being included in the POST
yet run I run it with the FME Server RestAPI webpage interface it is fine and shows up in the published parameters.
  • Jan 28, 2019 5:12 PM UTC
Could you also post the failed job log?
oliver.morris
  • Jan 28, 2019 5:23 PM UTC
job_325770.txt
The real reason is that the parameter isnt being passed, so there is something wrong with the api call I think - is it to do with the location of the fme token?
Thank you
  • Jan 29, 2019 8:10 AM UTC
job_325770.txt
Thank you
Regardless, I would not recommend passing the token on the URL, for security reasons. My recommendation is to put the token in the header.
Other than that, I suspect that @GerhardAtSafe is right.
oliver.morris
  • Jan 29, 2019 12:13 PM UTC
Thank you, I was just using the wrong endpoint, worked immediately after the change. Thanks Gerhard.
oliver.morris
  • Jan 29, 2019 12:14 PM UTC
Thanks David, yes I agree, although this is embedded within a stored procedure on sql server so the end user doesnt see any of it and it is just for internal use. Thanks for the help.
