Connecting to CKAN API
jiro
I have to carry out a project to produce and publish an interactive web map to disseminate data on traffic osbstructions and works in progress in Montreal.
However, the data used can be downloaded in CSV format from the City of Montreal's open data portal, but also accessible via the API provided by the City's open data team, the link is as follows:
https://donnees.montreal.ca/dataset/info-travaux/resource/cc41b532-f12d-40fb-9f55-eb58c9a2b12b
What is the complete workflow process to retrieve data from CKAN Web Service API using FME Form?
Attached is my incomplete workbench of my workflow that I tested using HttpCaller Transformer to test connection.
Please provide me with some possible solutions.
Regards,
danilo_fme
Forum|alt.badge.img+42
  • February 24, 2024
Hi @jiro
I created workspace to do this download and extract the informations.
Please, see attached file.
Thanks in Advance,
Danilo
jiro
  • February 25, 2024
Hi Danilo,
Thank you very much for your quick response and the attached workspace. The solution works perfectly for me as I just completed the workspace.
I appreciate your help. Below the completed workspace attached.
Best regards,
danilo_fme
  • February 25, 2024
jiro wrote:
Hi Danilo,
Best regards,
I’m happy to help you.
