Archived
Shutdown Scripts to run even if the process is aborted by the user
Related products:Transformers
jakub.olech
trentatsafe
siennaatsafe
virtualcitymatt
danilo_fme
+2
  • jakub.olech
    jakub.olech
  • trentatsafe
    trentatsafe
  • siennaatsafe
    siennaatsafe
  • virtualcitymatt
    virtualcitymatt
  • danilo_fme
    danilo_fme
  • cwarren
    cwarren
  • harmen_kampinga
    harmen_kampinga
virtualcitymatt
Similar to this idea: https://knowledge.safe.com/content/idea/87500/process-started-by-the-systemcaller-should-end-if.html I think more should happen when a user has aborted a workspace (or at least it could be an option workspace parameter).
In this case I think that a defined python/tcl shutdown script should run even if the user aborts the workspace.
As mentioned in this Q/A https://knowledge.safe.com/questions/87933/python-shutdown-scrips-when-workspace-cancelled.html there is a limitation when it comes to live streams, the only workarounds being pretty ugly in nature.
