Archived
Add option at writers to remove empty attributes
Related products:Transformers
lambertus
  • lambertus
    lambertus
If merging datasets or use the StatisticsCalculator grouped by many attributes it would be great if there was an option on writers to remove empty attributes. Especcialy if the filename (or sheet name in Excel) is set by an attribute. In this cases ther can be many attributes in the written files that are empty.
