XY Coordinate
  • Jan 5, 2024 2:47 PM UTC
  • 641 views
bayram
Forum|alt.badge.img+7
hello everyone
I want to produce a point from this data in text format and the XY values ​​I need are in a single stub. The FME dataset area is common for x and Y. I will bring these XY values ​​side by side and produce a point from the vertex creator, but I did not know how to do this.
daveatsafe
Forum|alt.badge.img+24
  • Jan 5, 2024 5:46 PM UTC
Hi @bayram​,
You can use an Aggregator transformer to group the records by fme_dataset, creating a list of the fme_text_string values. Then you can search that list with ListSearchers, using regular expressions to extract the x (1[0-9]+[.]*[0-9]*m) and y (3[0-9]+[.]*[0-9]*m) coordinates. Remove the 'm' from the coordinates using a StringReplacer, then create points using a VertexCreator.
Screen Shot 2024-01-05 at 9.40.02 AMI am attaching a workspace stub to illustrate.
bayram
  • Jan 8, 2024 7:58 AM UTC
Hi @bayram​,
Hello @daveatsafe​
Thank you very much for the answer, but I could not remove the values ​​from the list. I uploaded the excel data here. Can you help me if you have time?
1) xy values ​​in text string field
2) fme dataset field common field
I marked the xy values ​​with yellow color in Excel.
daveatsafe
  • Jan 9, 2024 12:14 AM UTC
Hello @daveatsafe​
OK, you have some other values in there that aren't coordinates, but are caught by the ListSearchers. We can tighten up on the regular expressions to solve this, changing them to 1[0-9]{5}[.][0-9]{3}m and 3[0-9]{5}[.][0-9]{3}m. This will only extract the true coordinate values.
I am attaching an updated workspace that incorporates your dataset.
bayram
  • Jan 9, 2024 5:20 AM UTC
Hello @daveatsafe​
Thank you very much for your answer, it is very successful.
