Navigator transformer lists missing
  • Nov 1, 2023 7:43 AM UTC
  • 136 views
koen
Forum|alt.badge.img+14
Since I upgraded to FME Form 2023.1 the transformer list options , such as "Upgradable Transformers" and "Incomplete Transformers" are missing in the Navigator, even when I have transformers in my workspace which are incomplete or can be upgraded.
Is there a way to enable this option?
Best answer by nielsgerrits
Hi Hans,
Thanks for your response.
I'm on build 23619.
Attached an example Workspace.
While creating this workspace I accidentally discovered the problem, but not a solution.
The problem occurs when I have junctions in my workspace. When I remove all junctions, the categories appear again. Is this a known bug?
Regards,
Koen
Looks like this is fixed in b23625 , see the changelog, can be found at the downloads page.
FME 2023.1.1.0 b23625 20230911
[Fix] Navigator: List of Upgradeable, Invalid, Disabled Transformers does not appear in the Navigator in some workspaces in 2023.1+
Forum|alt.badge.img+63
Which build are you using? I'm on 23636 and I have those categories in my Navigator. Are you able to share the workspace here?
koen
  • Nov 1, 2023 10:33 AM UTC
Hi Hans,
I'm on build 23619.
Regards,
Koen
nielsgerrits
Forum|alt.badge.img+67
  • Nov 1, 2023 12:02 PM UTC
Hi Hans,
I'm on build 23619.
Regards,
Koen
