I have filtered air temp into average daily max and min. And I would like to display them in two columns filtered by date and station. In the final table, only the max temp is showing in both columns. How do I show min temp as well?
Best answer by jdh
OK. It looks like what you want to do is after your Feature Reader have a tester for ParameterTypeLongName = Air Temperature, then your DateFormater (this is a performance thing, why format dates that you are not going to use)
Then an attributeCreator @Value(TimeSeriesName) = @Value(Value). This should give an attribute of either A.DayMax or A.DayMin depending on which row/feature it is.
Then an Aggregator with a group by on StationName and MeasureDate, in Accumulation Mode Merge Incoming Attributes
That will get both the max and min temp attributes on the same feature. You can then do any cleanup of attribute names (this may require an attributeExposer).
danilo_fme
Forum|alt.badge.img+42
  • March 13, 2021
Hi @robeesafe​
please, could you share the data?​
jdh
Forum|alt.badge.img+28
  • March 15, 2021
We would need to know the settings on your workspace to be able to help.
  • March 15, 2021
danilo_fme wrote:
Hi @robeesafe​
Hello Danilo, I have attached the weather dataset from which I would like to filter the “Air Temperature” out of “ParameterTypeLongName” and further filter A.DayMax and A.DayMin from “TimeSeriesName” to display as indicated in “tmp.csv”. Here is an image of the transformers I used: [cid:image001.png@01D71981.4FD5DB90] Let me know if you have any questions. Thanks, Robert Classification: Protected A
  • March 15, 2021
Hello JDH, I have attached the weather dataset from which I would like to filter the "Air Temperature" out of "ParameterTypeLongName" and further filter A.DayMax and A.DayMin from "TimeSeriesName" to display as indicated in "tmp.csv". Here is an image of the transformers I used: [cid:image001.png@01D71981.4FD5DB90] Let me know if you have any questions. Thanks, Robert Classification: Protected A
jdh
  • March 15, 2021
Hi Robert,
I'm not seeing either the image or the attached csv.kb_view
  • March 15, 2021
Hello JDH, I'm resending my earlier message with attachments. I have attached the weather dataset from which I would like to filter the "Air Temperature" out of "ParameterTypeLongName" and further filter A.DayMax and A.DayMin from "TimeSeriesName" to display as indicated in "tmp.csv". I have also appended an image of the transformers I used. Let me know if you have any questions. Thanks, Robert Classification: Protected A
  • March 18, 2021
danilo_fme wrote:
Hi @robeesafe​
Hello Danilo, Do you have any questions for me? I’m wondering if you have made on progress on the request. Best regards, Robert Classification: Protected A
  • March 18, 2021
Hello JDH, Do you have any update for me? Thanks, Robert Classification: Protected A
jdh
  • March 18, 2021
Hi Robert, I am not sure how you are sending the attachments, but they are not showing up in this forum.
  • March 18, 2021
Hello JDH, I'm sending them as attachments to this email. Is there another way? Thanks, Robert Classification: Protected A
jdh
  • March 18, 2021
Use the web interface. You can embed images and attach a file to your reply.
  • March 18, 2021
Here is one of the attachments. How do I send an Excel and csv file?Air Temp transformers
  • March 18, 2021
Example of air temperature source data
  • March 18, 2021
Desired air temp output
jdh
  • March 18, 2021
  • March 18, 2021
Thanks, your solution worked.
