I am extracting Shapefile. Coordinates are reversed. LONGITUDE, LATITUDE. I need to invert to latitude, longitude.location original is in Brazil but show in Atlantic Ocean. reading -54,-31 but correct is -31,-54 degreess. How do I fix the problem?
Best answer by danilo_fme
Hi @marcelocopetti​
I suggest you to use the transformer CoordinateSwapper:
CoordinateSwapper
Thanks in Advance,
Danilo
danilo_fme
Forum|alt.badge.img+44
  • March 11, 2021
Hi @marcelocopetti​
CoordinateSwapper
Thanks in Advance,
Danilo
danilo_fme wrote:
Hi @marcelocopetti​
CoordinateSwapper
Thanks in Advance,
Danilo
Thanks. Problem solved 100%.
Now need add number of table column into each map region. How subtitles to conect line table with region. numbers for example into local map if possible.
​Thank you very much. I am Brazilian and my english laguage is poor. Sorry. But sokved.
danilo_fme
  • March 13, 2021
Hi marcelo
I m a Brazilian too :) very happy to help you.
About the second step , could you share your data?
Se quiser pode me enviar email
Abraco,
Ola amigo. muito grato. Não achei o teu email para enviar direto. Em sáb, 13 de mar de 2021 01:20, FME Community escreveu:
danilo_fme
  • March 14, 2021
Recebido seu email, vamos conversar por lá. Abraço!
