How can I group my features based on one of their attributes and run each group separately?
  • August 5, 2021
  • 119 views
mahbouberezaiee
Hi. I have a lot of features in my workspace and want to group them based on the region, they are falling in, and then run the workspace for each region separately. How can I set up the workspace to do that automatically ??
Many Thanks
jdh
Forum|alt.badge.img+28
  • August 5, 2021
Option 1
Have a pre-processing workspace that reads your input data and writes it back out split by region.
Then you can run the actual workspace in batch mode, or have primary/helper workspaces with the workspaceRunner.
Option 2
Do you actually need to run the workspaces separately, or can you use a group-by throughout the processing, either at the transformers, or by wrapping them in a custom transformer.
Option 3
(for rectangular regions)
Expose the search envelope parameters on your reader.
Have a parameter for region name/id, and make sure the output path or filename includes it (or some other method of ensuring each succesive region doesn't overwrite the previous data)
Have a primary workspace that reads the regions data and extracts the bounds as attributes. Feed them into a workspaceRunner setting the parameters from the attributes.
Option 4
Primary workspace reads the region data and extracts the geometry as an attribute and passes it as a parameter in the workspaceRunner.
Helper workspace, Creator -> geometryReplacer (from parameter_->FeatureReader with with Spatial Filer OGC-Intersects.
