Hello, Within my workbench I need to obtain the values from a cell in the row above. But first I need to do some form of grouping and sorting to make sure I get the right values. Can anyone help me with how I can do this? Thank you!
  • Oct 26, 2020 12:12 PM UTC
  • 80 views
The data I have looks like the table shown in the appendix 'Current format'. I want to come to the result shown in the appendix 'Needed result'.
So I need some form of grouping based on the ID column. And also a sorting based on the BOTTOM_DEPTH or based on the DBK column.
Within each group, the first row needs to get a top depth of zero. All following rows need to get the BOTTOM_DEPTH value of the row above.
Best answer by ebygomm
Once you have sorted into the correct order, you can use the Adjacent Feature option in an Attribute Creator with a conditional statement to get the correct values. If the ID does not match the ID of the feature above, set the TOP_DEPTH to 0, otherwise set it to the bottom depth of the previous feature (feature[-1])
Capture
Forum|alt.badge.img+54
  • Oct 26, 2020 12:24 PM UTC
Capture
  • Oct 26, 2020 12:54 PM UTC
Capture
Thank you for the quick reply @ebygomm​! It indeed gives me the result I need :-)
