DWG font folder
  • November 12, 2020
  • 33 views
itay
Forum|alt.badge.img+17
Hi There,
I am using FME Cloud to translate data into DWG. In the writer settings I provide a folder for the  AutoCAD Shape File Folder, which is used in the translation.
However the log file also states:
No AutoCAD font folder specified. All Text and Multi-Text entities will use the default font file 'default.shx'
I expect the writer to use the shx file specified in the AutoCAD Shape File Folder, why is this not happening?
chrisatsafe
  • November 16, 2020
Hi @itay​,
Just to confirm, when you have the AutoCAD Shape File Folder parameter set you are still seeing this warning? If so, it sounds like this may be a bug. Additionally, what build of FME are you using? This was reported way back so it's possible that there was a regression that needs to be addressed.
itay
  • November 17, 2020
chrisatsafe wrote:
Hi @itay​,
Hi @chrisatsafe​ ,
I am using the following build: 20594 on FME Cloud.
