Standard Deviation calculations
  • September 4, 2024
  • 48 views
mr_fme
Forum|alt.badge.img+8
I have an NDVI raster and need to clip it with many polygons. After that, I need to calculate the standard deviation for each piece of the raster (clipped by the polygons), and in the end, I need to correctly assign the deviation value to the attributes of the corresponding polygon.
Thank´s
Best answer by redgeographics
I think you can use a RasterCellCoercer to turn the pixels into points (with the band attributes) and then run a StatisticsCalculator
Forum|alt.badge.img+49
  • September 5, 2024
