Stable token to ArcGISOnline (AGOL)
mark_zl
I am trying to connect to AGOL but my token expires. I followed the method in https://community.safe.com/s/question/0D54Q000080hYdzSAE/how-do-i-reliably-connect-fme-server-201819-to-arcgis-online.
tokenIt work s but then stops working
Any suggestions to to fix this?
Under File & Connections, I click web connection, then select connection and click manage web services
FME_agol
On AGOL developer I selected
 FME_auth
nielsgerrits
Forum|alt.badge.img+53
I think you forgot to set the Redirect URI in FME Server, under Connections, Web Connections, Manage Web Services. It need's to be https://<your fme server adress>/fmeoauth (like https://etl.company.com/fmeoauth)
Don't forget to add the redirect uri to the app in ArcGIS Online.
mark_zl
  • July 18, 2021
Thanks yes when I put the redirect URL it allows me to Click on the connection and Authorize. So everything appears to have worked. But when I run the workspace it still gives a token error.
error
mark_zl
  • July 18, 2021
Solved the problem, we logged in as the server user and authenticated the AGOL connection and it now works.
