Problem with exporting to Excel
lazarlubomir
Forum|alt.badge.img+7
Hello, unfortunately I have repeatedly problem with exporting to Excel in Workspace. I checked log, there is following message: 2016-11-24 10:05:57| 67.6| 0.2|ERROR |Excel Writer: Failed to save changes to the spreadsheet 'D:\\XXX\\XXX\\XXX\\new.xlsx'. Check that you have write permission to the file, it has no password protection and is not opened by another application. Error message is 'Permission denied.'
It looks, that there is error on Excel side, right? I just want to create new Excel file...
  • November 24, 2016
Does the directory already exist? If not, create it manually.
Does the file exist? If yes, try to delete or rename it.
itay
Forum|alt.badge.img+17
  • November 24, 2016
Another tip, check the task manager to see if the xls process is still running.
lazarlubomir
  • November 24, 2016
Directory exists, there is not a problem. File doesnt exist. And Log still throws the same message...
lazarlubomir
  • November 24, 2016
Unfortunately - XLS process is not running and problem is still there...
  • November 24, 2016
That is a strange error. Have you tried rebooting?
Obligatory:
itay
  • November 24, 2016
Obligatory:
Yep sounds like the workspace needs restarting since it's holding on to some old definition
via GIPHY
lazarlubomir
  • November 24, 2016
Obligatory:
Even when I reboot workbench, problem is still there :-( I feel little bit hopeless
  • November 24, 2016
Try rebooting your pc as well.
lazarlubomir
  • November 24, 2016
Still the dame problem, even after rebooting my laptop :-(
  • November 24, 2016
Do you have any weird or accented characters in the path or filename? Can you create the file manually using Excel? How about changing or simplifying the filename, does that work?
lazarlubomir
  • November 24, 2016
@david_r path is ok, take a look: D:\\projekty_CS\\AC_SK\\dfsda.xlsx. There is no problem with characters or something else. I can create and save Excel (using MS Excel) without problem.
itay
  • November 24, 2016
Sounds like a case for Safe support to me.
fmelizard
  • November 24, 2016
I'd also suggest writing to CSV in the same place and make sure that works. Please do send in all the info to support@safe.com -- logs and workspaces -- and then we can examine.
pratap
Forum|alt.badge.img+11
  • November 25, 2016
Just try in different path and file name.
mark2atsafe
Forum|alt.badge.img+43
  • November 25, 2016
pratap wrote:
That's what I was thinking. Maybe there is a permissions limitation to stop you writing to that directory. Try a different path and see if the error occurs (or write to CSV to the same folder as Dale suggests).
Also, are you running this on FME Server or FME Desktop? I'm guessing it's not Server, but if it was then that's a likely place to check too.
gmbutler2
Forum|alt.badge.img+10
  • November 28, 2016
I have had this issue before as well. I have found that sometimes it won't overwrite the existing file if there is one. Also, I have seen this error pop up if you have excel open (not the specific file you are saving but excel itself). I either do one of the following.
1. You may have the file you are trying to save open. Close it and try again.
2. This sometimes occurs if the Microsoft Excel program is open. Close all instances of Microsoft Excel and try again.
3. If you are trying to overwrite a file and it is not open, try deleting or renaming the original export through windows explorer and try exporting the data again.
lazarlubomir
  • November 29, 2016
@gmbutler2 Thank You for tip! Problem is probably on my OS in laptop... Even if I try use your tricks, it fails... Anyway, I use exporting to CSV file and then I open it in Excel and save in xls.
lazarlubomir
  • November 29, 2016
@daleatsafe I have contacted my supplier of FME and we will try to solve this problem :-)
gio
Forum|alt.badge.img+15
  • December 1, 2016
not writing tabs with spaces in tabnames? (feature_type) that will cause write-fail.
pmt
Forum|alt.badge.img+3
  • August 23, 2024
If the output network drive is not mapped, or you don’t have access to the output location, you will get that error.
pauldeq
  • December 9, 2024
I don’t know if this will help, but I noticed that my issue was that I was adding “:” to my file name, and that is not a legal character for a file name. Are you sure that the “\\” in your file name “D:\\XXX\\XXX\\XXX\\new.xlsx” is right? I always thought that it was D:\\ and then each sub folder was a “\”? Like maybe the issue is that you are putting “\\” in places that don’t need it? Just a thought.
