microstation model space
  • Aug 28, 2017 5:19 PM UTC
  • 5 replies
  • 78 views
cprhamel
Hello everyone
I would like to know if with a dgn V8, it is possible to create space model centered on the rights of the main file At the same time that the file dgn is created thank you
danilo_fme
Forum|alt.badge.img+58
  • Aug 29, 2017 1:17 PM UTC
Hi @cprhamel,
Could you share us more detalis about this case?
Thanks,
Danilo
danilo_fme
  • Aug 29, 2017 1:33 PM UTC
@cprhamel, has a link about space model in DWG
Layouts
Thanks,
Danilo
cprhamel
  • Aug 29, 2017 4:54 PM UTC
The solution for dwg me goes
I have a dwg file with in the multiple zone model And for formatting the presentation I would like to create layouts centered on each zone To display a legend, a cartridge ...thanks
danilo_fme
  • Aug 29, 2017 5:48 PM UTC
Coul you share a sample data?
Hi @cprhamel
when you write a dgn-file, models are copied from your seed-file, i.e. you would need to have a model 'centered on the right of the main file' predefined in your seed-file. If you need to define models dynamically, would you mind posting an idea?
