Does FME 2021 support ARcGIS Pro 2.7 python API, i.e., arcpy
aguan
Forum|alt.badge.img+11
My current FME 2020.1.3 works with arcpy from ArcGIS Pro 2.5 and 2.6, but not 2.7. Does the latest FME 2021 support ArcGIS Pro 2.7?
Best answer by sipsysigh
Hi @aguan​
For FME and Esri Version Compatibility, this is a useful link:
https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
ArcGIS Pro 2.7 is compatible with FME 2020.2.2 or higher (64-bit only), so you should be covered for FME 2021.
Updated to add:
I have FME Desktop 2021.0 and ArcGIS Pro 2.7.2 installed on my machine. I can successfully import the arcpy module using the PythonCreator / PythonCaller Transformer when Python Compatibility is set to Esri ArcGIS Python 3.7 in FME Desktop.
Thanks,
Simon
sipsysigh
Forum|alt.badge.img+7
  • March 16, 2021
Hi @aguan​
Updated to add:
Thanks,
Simon
aguan
  • March 17, 2021
sipsysigh wrote:
Hi @aguan​
Updated to add:
Thanks,
Simon
@sipsysigh, thank you. I will try 2021 then.
