can I compress a file geodatabase that I am writing to in FME
  • November 25, 2015
  • 132 views
Is their a way to set my file geodatabase writer to comress itself somehow?
Best answer by takashi
Hi, if you are using the Esri Geodatabase (File Geodb ArcObjects) writer [GEODATABASE_FILE], there is an advanced writer parameter called "Compress Database When Done". Or, if you need zip compressing, insert your desired zip file name (*.zip) as the folder to the Dataset of the writer, like this: "C:\\data\\output.zip\\dataset.gdb"
Forum|alt.badge.img+21
  • November 26, 2015
  • January 7, 2016
Great answer Takashi! One additional note is that 'Compess Data When Done' was originally mislabeled; it actually 'Compacts' the Geodatabase. The label has been updated in FME 2016.
runneals
Forum|alt.badge.img+19
  • April 30, 2019
@takashi Do you know if there is there a way to get the gdb as the root of the zip instead of having it be nested inside the zip?
  • May 1, 2019
Once you created the destination File Geodatabase dataset (***.gdb) with a FeatureWriter, you can then archive all the files under "***.gdb" into a zip archive (***.gdb.zip) using another FeatureWriter with the File Copy writer.
