ArcGIS Online AGOL - reading and writing Attachments to local gdb
gis_queen
Can't find a clear answer on this - is there a way to read from AGOL and write all data including attachments to a local gdb? I found the bit about the dropdown to include attachment and expose as an attribute but this isn't really helping.
Does anyone have guidance or a workbench they can send that brings this data through with the actual image or file attachments on the feature itself as it appears in AGOL?
Thanks!
bruceharold
Forum|alt.badge.img+17
  • March 29, 2019
If you have ArcGIS Pro try the Feature Class to Feature Class geoprocessing tool with the environment setting Maintain Attachments set.
lars_de_vries
Forum|alt.badge.img+10
You could also try to go the REST API interface in ArcGIS Online and Create a Replica. This could also be done with the REST API and an HTTPCaller.
I wrote an article about it, which you can find here.
  • April 3, 2019
@heartlacey
It seems there is still no direct and one-tool way to read and write AGOL Feature service with the attachments into a geodatabase. This is primarily due the way the geodatabse stores feature classes with attachment, i.e. using 3 different tables: feature class, attachment table & a relationship class.
I found a template in the following link that helped me achieve this. Scroll to the bottom of the link and download the zipped file. You just need to customise the setting to meet your needs. The workflow works really well.
