2d dwg to 3d ArcGIS
I have a 2d dwg file.I want to convert it to a 3d one which can be used in ArcGIS10.I want some advice,examples or documentations.THANK YOU.
Best answer by takashi
I suppose autocad_* is a kind of the format attributes. If so, you can expose them by checking "Exposed" check box in the Format Attributes tab of the Feature Type Properties dialog box. Click [...] button of the source feature type object on the canvas to open the dialog box. Alternatively, you can  use the AttributeExposer transformer to expose those attributes.
Takashi
  • July 4, 2013
The 3DForcer transformer converts a 2D feature into a 3D one.
Takashi
sigtill
Forum|alt.badge.img+24
  • July 4, 2013
Can you supply a small example file?
  • July 5, 2013
In FME Data Inspector, my elevation information is a point with a number nearby.The point is an autocad_hatch, the number is an auto_cad text. So, can you tell me how to use this elevation information in ArcGIS? Thank you .
  • July 5, 2013
Takashi
