getting error “QSInvalidRequest”
swethabhupathi
Forum|alt.badge.img+3
Often getting error “QSInvalidRequest” while an automation triggering a job at scheduled time
hkingsbury
Forum|alt.badge.img+53
  • April 2, 2024
Hey, you’re pretty light on details here. Can you flesh out your issue a bit more and include things like where this error is occurring, relevant lines from logs files etc
nielsgerrits
Forum|alt.badge.img+54
You could try and elaborate a bit more about your issue, but when I search for similair topics I only find one:
Where it is suggested to submit a case with Safe Software:
https://support.safe.com/s/submit-case
swethabhupathi
Hi, There is automation configured in FME server. It will trigger a job for every 15mins.
i am getting above error message while it triggers the job at scheduled (15mins) time for few times and it is repeating after few successful triggers.
hkingsbury
  • April 3, 2024
Is your automation doing anything more than simply triggering a job?
swethabhupathi
No,,,Its just triggering the job at scheduled time
hkingsbury
  • April 10, 2024
Does the issue happen when you:
  • run the job manually through Flow
  • use a schedule rather than an automation
  • create a brand new automation
swethabhupathi
  • run the job manually through Flow...its working
  • use a schedule rather than an automation...i can. But, i want to know the reason fo rgetting this error
  • create a brand new automation...Even after that also getting same issue
hkingsbury
  • April 10, 2024
With the above tests it sounds like there might be a bug in automations, it would be best to reach out to your reseller or open a support ticket with Safe.
