Two Lookups
  • Aug 31, 2018 2:05 PM UTC
  • 95 views
I am a beginner FME user having trouble with using a lookup table. I would appreciate your help.
I will need to perform two lookups (there are plenty of examples here using a single lookup).
The primary dataset has a structure like this:
SEQID1ID21FTYCOM2PRDDCY
The lookup table provides a name for each ID:
IDNAMECOMCommodoreDCYDiscoveryFTYFtypePRDPradoCORCorollaFALFalcon
I would like to perform the two lookups for each row of the primary dataset in order to achieve the result:
SEQID1NAME1ID2NAME21FTYFtypeCOMCommodore2PRDPradoDCYDiscovery
The above examples are simplified. Both the primary dataset and the lookup table contain thousands of rows.
Any ideas please? [Did I mention I'm a beginner? :) ]
Forum|alt.badge.img+54
  • Aug 31, 2018 2:37 PM UTC
I would use an inlinequerier for this
Select
  p.SEQ,
  p.ID1,
  l1.NAME As NAME1,
  p.ID2,
  l2.NAME As NAME2
From primary_table p
Join lookup l1 On ( l1.ID = p.ID1 )
Join lookup l2 On ( l2.ID = p.ID2 )
fmelizard
Forum|alt.badge.img+22
  • Sep 1, 2018 8:02 PM UTC
@egomm's technique will certainly work and work well. The slightly easier-to-set-up way is to use a traditional reader to read your pimary dataset, then go into a DatabaseJoiner to do the ID1 lookup, then copy that DatabaseJoiner transformer and connect it at the end and do the ID2 lookup.
  • Sep 2, 2018 8:18 AM UTC
Thank-you so much @egomm and @daleatsafe - I will try both techniques for my education.
